Thanks for the reply.
There is in fact a separate mode that facilitates automatic current detection, but it is not part of the same mode.
The manual seems to give the impression these pauses are for performance/efficiency reasons, not for taking measurements (you can also set a mode that does not pause, but you can still enable peak detection and auto-current).
Normal: The charger will work with the parameters which were set at the screen. The feeding current will be at zero every 90 seconds to have 6 seconds of waste-time for higher charging efficiency.
And the auto-current mode is detailed in a separate section. Curious.
