Muggydude
07.24.2010, 11:36 PM
Just camE back from the skatepark.... Success! No broken parts, stripped gears, or heating problems. I must have run it for over 30 minutes total run time, cause I spent a good chunk messing around in rocks and a playground at about half speed. Not very many highspeed passes, just low-mid speed runs. The skatepark was a lot of fun, a little too crowded, but i got some good jumps in. This thing is easy to control in the air, and flies well. I think I'm going to switch to some stiffer springs, I had my setup at 60 wt oil, p2 rockers, inner hole, Black rear springs, gold front. Any suggestions for stiffer spring setup? When I got home and threw the batt on the charger, it was at 14.7 volts, so I think that's is just fine. I never even hit the LVC, or use my second batt. I really like these turnigy batteries. I'll keep you udated as I test it more. This peoject has finally come together, and I'm really happy with it! Can't stop smiling!
By the way, I have displaced all doubts about how strong this CF chassis is. It's really durable!
(Real quick Q, 14.7 volts is normal for 4s, right? I believe I have the LVC set at 3.1 volts per cell. It was just barely warm when I stopped)
R.I.P. Muggy, Rustler, VXL Slash
EFlite Blade MSR Heli (Slightly modded)
1/16 BL E-revo
8-t 2.0, OS Vspec with Speed conrod
Carbon Fiber Revo 3.3 Coversion Madness!
