Quick question about soldering a motor & grinding a flat rotor spot.
Byte
08.03.2010, 03:55 PM
Originally Posted by
What's_nitro?
Usually. It's more precise than a Dremel tool and there's no risk of accidentally going too far.
Here are the files I use.
The flat file is about 1/4" wide, perfect for making the flat areas on motor shafts.
How long does it take to file a 5mm shaft? I have to grind a flat spot on a 1/2'' shaft in the future....
Byte
