I ran this today with 10s Turnigy 5000mAh 40c. I had to gear higher since my 16t pinion was broken. Gearing set-up:
Differential Ratio: 4.090909090909091
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 48
Pinion Tooth Count: 17
Total Voltage: 37
Motor KV: 825
Tire Diameter (inches): 6.84
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0.012
Spur/Pinion Ratio: 2.82 : 1
Total Ratio: 11.5508 : 1
Tire Circumference (inches): 21.49 inches (545.81 mm)
Rollout: 1.86:1
Total Motor Speed: 30525 RPM
Vehicle Speed: 53.78 mph (86.38 km/h)
Effective KV Value: 825
KT constant: 1.64 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
Here's the voltage and current log:
Max current: 98.9Amps
Max power: 3619W
Temps at end of run:
ambient: 80F
esc: 122F (internal) 138F (external)
motor: 168F
batteries: 112-120F
So, I'd say my temps are about the same as 8s, considering I was geared slightly higher today. So much for my hope that 10s would bring my temps down. The only advantage might be battery temps were slightly lower - since I'm not pulling as much current as on 8s.
Then other thing I see is that my 5000mAh Turnigies seem to be giving out. I only used 3.97Ah today before hitting lvc.
So I need to look for some new packs - as much capacity as I can fit in this, I'll probably go with 10s, although it doesn't seem to matter.
