Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.08.2010, 07:24 PM
Not sure if were on the same page ?
The metal rings from the stock carriers must be removed and installed on the RPM carriers or the balls will pop out.
Popoxx
Sapere aude
Popoxx's Avatar
08.09.2010, 01:12 AM
Confusion confusion
These metal rings are not metal rings but plastic rings require to use the inner bearing of the previous Traxxas axle carriers which didn't have built-in metal rings around the pivot balls. And RPM carriers don't use the same bearings so these plastic rings are useless here. I hope all is clear now !
