Thomas Porfert
Thomas Porfert's Avatar
08.13.2010, 10:07 AM
I think that was to cut down on Tech support phone calls from people with four and six pole motors....
Wooo whooo!
Originally Posted by Fajita Dave View Post
How do you get the test to work in the first place? No on answered that for me in my last post. I've tried it with my Sidewinder speed control and the data never shows up even with V3.255.
Make sure you have actually updated your Sidewinder to the latest firmware version. You must have 1.28 (now 1.29) on your controller to get the torque limit feature. Simply installing the latest software on the computer won't give you the latest firmware and any new features associated with that firmware. If you have updated to the latest firmware, then I'm not sure why you don't have the torque limit setting.
Thomas Porfert
Castle Tech Support
armourbl
08.13.2010, 10:55 PM
Any truth to the claims that the latest firmware is causing Mamba Pro units to go up in smoke? I know someone that personally had this happen, and read about it happening to others.
I'm very hesitant to upgrade my Mamba Monsters because of this.
ben
Pdelcast
Pdelcast's Avatar
08.14.2010, 12:39 AM
ben
Haven't heard anything about Mamba Pro, and I check the boards regularly -- Mamba Max had a glitch where the new software would make the on-board USB stop working -- but that software was fixed right away.
That's it. This newest version stop the "hesitation" that some setups were seeing when using torque limiting.
Thanx!
Patrick
Patrick del Castillo
President, Principle Engineer
crazyjr
crazyjr's Avatar
08.14.2010, 05:00 AM
I have not tryed the torque control yet, But the 3.26 castle link and the v. 1.29 mamba revision is working great on my mamba max.
One question on the torque control, Do you need to hook up a battery to the esc to do the kv check? I'd like to try the torque control but not sure what i need to do to activate it
One more thing, Big shoutout to castle's support. They sent me a castle link at no charge to fix my mamba max after i lost the usb due to the first update in this thread. Due to the support i got, My next esc will be a castle mamba.
Pdelcast
Pdelcast's Avatar
08.14.2010, 10:18 AM
Crazy -- yes, you need to hook up a battery so the ESC can do the Kv check. Thanx!
crazyjr
crazyjr's Avatar
08.16.2010, 02:32 PM
thank you Pdelcast, may try it this week
