E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
08.16.2010, 05:44 PM
Good luck Brian! My Mom and step dad have had continuous flooding in their basement, mostly through the sewer line. They wound up putting a one way valve in, similar to a check valve, but it had a special name. When there are water issues now there basement is dry but if that valve shuts they can only get about two flushes before the drains stop working. I would rather have to rent a portapotty and keep the basement dry myself so I think thats a small trade off. They had their washer, dryer, furnace, hot water heater, and freezer replaced twice because of flooding. Each time they raised things up higher. Their basement is only about 6'4" and they have their furnace and hot water heater almost 3 feet off the floor so if you have a deeper basement 4' shouldn't be a big deal. There are shorter furnaces that you can get, they're just fatter, I'm sure that you can get similar hot water tanks.
Gave a few cookies to your calculator, I've used it enough, hope it helps
Any chance
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Any chance - 08.16.2010, 06:17 PM
Hey BG any chance you can re-locate your furnace and hot water tank some place other then your basement? I moved our natural gas furnace to a closet on the first floor, and I converted the hot water heater to an electric one and it is now in the garage 24" off the floor. Just a thought. Plus I did it all myself. If no garage you can even build a small out building on your house for placement pretty cheaply. It may cost a bit more to relocate things, but compared to having to replace it every two years or so it usually saves money. I was even able to install a digital timer on our hot water heater (for $75 at the Home Depot) so the heater only draws electricity a few hours a day. 2 hours in early morniing and 2 hours in the evening. That way you can limit how much damage is done if water gets into your basement again. Maybe even try talking with your insurance company for assistance, which will save them money down the road. Sometimes they are willing to help $$$$ when it can benefit them on future claims. Good luck with that.
SUPERMAXX YOUR LIFE.
