Go Back   RC-Monster Forums > Support Forums > CORR Trucks - Slash, SCRT10, etc.
Thread Tools Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Shark413
Shark413's Avatar
08.17.2010, 05:17 PM
The main weakness on the SCRT10 is the front bumper. It has a tendancy to break the upper mount or the lower part will pull out from the chassis. I am running a T-Bone modded bumper. It mounts under the chassis (which is either good as it acts as a front skid, or bad, because it reduces ground clearence). It has been holding up well so far.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
Shark413
Shark413's Avatar
09.10.2010, 05:57 PM
A few more updates:
I have replaced the stock aluminum chassis with a SNR carbon Fiber one. I also removed the larger center diff top plate with a smaller CF plate. I added the PBS front suspension and moved all the electronics to the chassis to lower the CoG. I lost almost a pound from what I was originally running.
SNR CF chassis
Bottom
I added a Chassis protector film
Mudguards added
Shark413
Shark413's Avatar
09.10.2010, 06:05 PM
A few more details:
I made a small bracket to help hold the rx in place. The rx is mounted with d-tape but since it was so close to the spur/driveshaft I didn't want to chance it coming loose and getting sucked into the gears, so I made a bracket that mounts to the steering servo mount and clamps down on the rx. I also made a bracket that helps support the motor wires (keep flexing to a minimum) and keeps them from getting tangled in the driveshaft. I also added velcro straps to the battery box. They are more secure and allow for taller batteries to fit.
All the electronics mounted low on the chassis.
I made a small bracket to help hold the rx down.
A wire support to keep the motor/esc wires out of the driveshaft.
Shark413
Shark413's Avatar
09.10.2010, 06:11 PM
I mainly went with the CF chassis because it was lighter but also because my stock aluminum chassis was bent.
Here is my stock chassis placed on a straight edge (ruler), you can see daylight where the chassis is bent up.
Captured ball links to prevent pop outs and bending.
PBS suspension has a much stronger upper arm and allows for caster adjustment.
RC-NUT
RC-NUT's Avatar
10.27.2010, 12:12 PM
Nice truck man!! I haven't been on the boards in quite a while but I picked up a Jammin in September so I had to chime in. I really like your ideas.
My beef with the stock chassis was all the extra "nitro" holes that were not used. There harmless but just annoying considering how much we spent for a roller. I need to look around and see where you bought that chassis.
Did you take the front end off of a CRT.5? I have never seen one in person.
I have been running the new Novak Ballistic 550 4.5 system with horrible luck. It's fast, smooth, and runs cool when it's not bursting into flames. I'm picking up my third system tonight after the first 2 blew up. The second one was literally in flames. I'm only running 2s and a low gear. It never reaches 100 deg. Weird?
Again nice truck!
Shark413
Shark413's Avatar
10.27.2010, 03:10 PM
Again nice truck!
Thanks, I have been running an older Novak 4.5 HV with a MMP since March with no problems at all and I have been very happy with it. I have been posting regular updates on this thread, check it out:
http://www.rcshortcourse.com/forum/s...ead.php?t=4672
Again nice truck![/
