Thanks for the guesstamate,
I am at a total loss trying to figure this kinda thing, as you can probably tell it's all new to me, ...man its really great that you guys are willing to help a struggling stupido here.
I am far below par with the math and what makes it worse; I dont even know the formulas.
I have not bought the Ofna 51t spur yet...I just want to be relitivly sure that Mod-1 1/8" shaft pinions will be available to dial in the truck before I jump in there...If not; I may have to scrap the idea of running with that slipper/spur with 51 teeth.
If any one has any thoughts on this; I would be very appreciative
I use the stock setup on most, and the Robinson slipper on others. I have one Kipster slipper, which uses the robinson spur gears, but the slipper mechanism works like the Strobe. This is the best on I have (best 32 pich slipper I know of), but I think Kippster no longer offers any products. The stock slipper will hold up if you use 12 pegs and crank it all the way down (don't allow slippage). This makes throttle control very important with these high powered beasts, though, as you can't tune power delivery with the slipper.
Here's a gearing calculator that'll get you in the ball park. You'll just need to knowyour tires diameter and transmission ratio; then you can play with the spur and pinion numbers to see what would be a good starting point. Then check the temps after running a pack, if you can't keep your finger on the motor for at least 5 seconds, you'll want to drop down a tooth or 2 on the pinion.
Pretty much. A smaller one won't fit the slipper and a bigger one would probably bind with the driveshafts. There aren't a lot of sizes available that will even fit.
