08.22.2010, 06:35 AM
If you are running an external BEC and its still dropping out it has NOTHING to do with the ESC.
I'm guessing that your batteries are dumping massively and causing the issue.
BashemSmashem
08.22.2010, 07:51 AM
Whatever , I am using 5200 Mah 30c batteries that are fairly new and a 8000 Mah 25c battery that is about 3 months old .
These batteries work great in everything I own except the truck with the MMP in it .
The motor and batteries also worked fine with the 2 other ESC's that were in the truck before ?
08.22.2010, 05:51 PM
I'm not sure what it is then (dodgy RX) but if you've run a Castle Bec and it still cuts out you've ruled out the ESC being the issue...
