Finnster
KillaHurtz
Finnster's Avatar
08.22.2010, 09:10 AM
Originally Posted by josh9mille View Post
I fixed that on mine with some thin gasket paper i picked up from the local auto parts store. I used the quare ridge in the skid plate as a template and just cut it out with a razor blade, fits perfectly and keeps all the dirt out of the diff. Plus you can still take the skid plates off, unlike using silicone where it might act like a bonding agent. You can also use thick paper if you want. I did this before i ever even ran my flux and its always been as clean as new inside and im still using the same piece of gasket material after probably 6 or 7 times of taking it appart
That's a good idea. I kinda like the hole as an easy way to inspect the diffs, but too much fine dirt gets by
