08.22.2010, 05:51 PM
Originally Posted by BashemSmashem View Post
Whatever , I am using 5200 Mah 30c batteries that are fairly new and a 8000 Mah 25c battery that is about 3 months old .
These batteries work great in everything I own except the truck with the MMP in it .
The motor and batteries also worked fine with the 2 other ESC's that were in the truck before ?
I'm not sure what it is then (dodgy RX) but if you've run a Castle Bec and it still cuts out you've ruled out the ESC being the issue...
