JThiessen
JThiessen's Avatar
08.27.2010, 07:18 PM
Nard, I couldnt read the numbers on the second pic....enlighten us!!!!
Finnster
KillaHurtz
Finnster's Avatar
08.27.2010, 10:42 PM
looks like 3772g to me, so he lost 228g. Not bad at all.
_dV
08.28.2010, 01:22 AM
No doubt that the FLM chassis is lean but Nard's weight loss would have come mostly from the removal of the stock battery boxes (~130gm each) and the radio box (~140gm). Freeze won't get the benefit of either of those.
Freezebyte
08.29.2010, 03:58 PM
Part 9: Battery tray mods and skid plate
The end is in sight! Now we all have left to do is final assembly of the chassis, battery tray mods, order and paint the body! So lets get to it, I wanna drive this thing soon!
The flux's battery trays are substandard at best after dealing with them on my first Flux. Without some modification, I found it nearly impossible to get any Lipo to fit decently inside, depending on how the wiring came out. Even with "Frostbyte II" extended savage frame, I still wanted to place more of the weight on the font of the truck to increase forward traction and reduce wheeling.
Were first going to go ahead and remove the all but usesless rubber clip holders as I'm switching the trays on the chassis so the top lid opens outward to allow for easier battery access. With that, we need to also remove the clips as they are now useless in reverse position
Next, I clipped off the forward, slanted section the tray lids. This allows me to slid the Lipo's all the way forward into the tray
I'm then cut out some shaped pieces of foam to keep the Lipo's from shifting in the tray. Once again, im going to use velcro straps to keep the batterys secured.
I then clipped off part of the rear section of the tray lid to allow the wires to easily exit out.
With some last bit of trimming of the foam to keep the Lipo's securely in place, our battery tray mods are all done!
Now its time to seal up the bottom of the Flux with our sexy skid plate thanks to FLM. I decided to go ahead and use the small hubs to attach the skid plate rather then the braces themselves for the time being to see if they would hold up under bashing abuse, not to mention the braces included hex screws don't fit flush with the skid plate either.
With a little bit of blue loctite on each of the screws to keep them from getting loose, my tranny is now safe and protected from the rigors of bashing!
Lets throw our new tires on and see how she looks now!
Wooo, I'm getting close to completion of "Frostbyte II"! Our final step is for me to make up my mind on a body, figure out a cool paint and decal scheme and then take this thing out on its maiden drive! Hang tight folks, the grand finale is coming up!
Nard Cox
n00b
08.30.2010, 12:11 PM
True Finnster, I lost 228gram with going XL.
That's indeed were I cut weights.
Freeze it's looking good. As for a body, me next one will be a SC as well. Am curious to see what you got / are going to get.
bryan
bryan's Avatar
08.30.2010, 01:56 PM
Yup S/C bodies are big and cool i've got a desert rat on one of the Muggy's
