I would ditch the axle extenders and run a wheel with more offset, just casue axle extenders are no replacement for longer arms... The higher offset wheel will put more load on the bearings, but you will loose a little bit of width and likely gain some steering and agility back. Stock flux is pretty short/narrow, so it should be agile and turn well. Trade off is that the longer chassis should be more stable.
