nitrostarter
nitrostarter's Avatar
09.03.2010, 12:07 PM
I've watched that video a couple times over and over. Thats pretty amazing! I for one was skeptical but now see that its completely do able.
Which if you think about it, a boat hull at full throttle pretty much only has the prop in the water. Thinking in this prospective, the only thing in the water will be paddle tires, much like a prop. Where a boat differs is the ability to stop, float, and start up again and plane off. If you are to stop, no planing off..
Originally Posted by Finnster View Post
My thinking is w/ PBO on the water issue. At the very worst, you could put a few small drain holes in the tire tread. Cent force will fling the water out quickly.
I do this with all my tires. I seal off the rim holes and punch holes in the tires. I use a hole puncher like this:
N. Rustler conversion
