Oh come on.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Oh come on. - 09.03.2010, 08:48 PM
Get a spool of 20Lb+ fishing line to put on a pole, make sure you have enough to cover the run. Let it free spool off the reel. It shouldn't add any resistance but if it does sink, you can get it back. Adding foam floatation to hold it up would add weight.
Oh come on. You could add a piece of bubble wrap or a packing air cussion that would weigh what like 1oz. Yes the string idea would work as well, but that adds one more item to the mix that you have to worry about while you are driving. KISS keep it simple stupid. That video was a nice run and if everything goes just right that is what you will end up with. Nice run whoever did that.
SUPERMAXX YOUR LIFE.
