You can use the 1518 at the same voltage of your 2200Kv, to keep the same top end you just need to increase the pinion size. You will gain a little runtime because the 1518 will run a little more efficient than the 2200Kv.
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
