How to build a $19.99 power supply
sujuara
How to build a $19.99 power supply - 09.08.2010, 09:28 AM
First step: buy any computer power supplies...
_TUE5110_resize
i bought one for only $15 .. rated at 860W
If you look closely at the image below... my +12v is giving me 17A+19A= 36A... Well this is kul enough
_TUE5109
2nd step: Only 2 colors that you need to remember
YELLOW: 12v output
Green : TRIGGER to turn on the power supplies ( to turn on: connected this to ground = earth = black cable)
3rd step:... open the box... and remove all of trunky cables...
4th step: pick your own cable ( 8g, 10G).. in red and black color...
RED conect to +12v Output ( which is yellow in color)
Black connect to Gnd
Buy yourself ON/OFF switch, then connect 1 terminal to Green cable, the other terminal to GND
_TUE5112_resize
Well... looks like things now ready ....
SWITCH on ....
_TUE5123_resize
_TUE5119_resize
By the way, the charger you see in the pics.. is pretty much same as the Imax quattro B6,
but have 4 x 60W > quattro B6 power...
And charger is only $120 US from rc-mushroom
