Originally Posted by Dj_Sparky
Was wondering about some good motor mounts for the 1717. Specifically for Savage apps.
And what do you guys for for Pinions? Where can I find 6mm pinions? :S
They use standard hole spacing and use any normal mount.
The 1717s now come with a 5mm shaft, if you already have it you can get a 5mm shaft from castle to replace your 6mm shaft.
I've only seen one 1717 in a savage and it was a completely custom job. Because of the size of the motor it just does not fit into regular spots well. For a savage you will need something custom.
I have seen several 1717s in LST's. They bolt up using a TheDudeRacing motor mount.
Good luck!
