Closed Thread
09.14.2010, 08:17 PM
continued...
5: RC18. SOLD
6: A couple MM ESCs. Both never ran. One is BNIB with whatever is inside the box. The other is new, but missing manual, CD, USB cable, etc.
7: HobbyWing 80A ESC. Used. Works well. I replaced the little program/on-off switch with a sealed setup (in a micro servo case).
8: Rockford Fosgate Power 600.4 amp. Got it refurbished from RF, never installed it. Did run it on a PS for a bit to test it and all channels work fine.
- 100w rms x 4ch into 4ohms.
- 150w rms x 4ch into 2ohms.
- 300w rms x 2ch bridged into 4 ohms.
8: A Phoenix Gold basscube. Lets you adjust boost frequency and level from the front of the car. Also has a subsonic filter. The cable connecting the units was cut, but I kept the ends as an example when making/buying a new cable. It's a regular telephone cable, so nothing major. The front control has a panel hotglued to the rear to prevent stuff from getting in the little box.
Do not want to spend a lot of time on this sale. Make an offer via PM. If good, I'll take it, otherwise it will go on craigslist/ebay, or just gather dust...
Closed Thread
