Update: Body changes
With the project wrapping up at long last, I had to settle on my final ideas one way or another. After some research at the LHS, I determined the amount of work needed to tint the bodies windows isn't worth the further expense and time needed to complete it, so that idea was scrapped. I did decide to go ahead and use as much Shoe Goo as possible to help reinforce the likely weak area's on the body I felt that would be subject to cracking under bashing conditons, due to the wide and long nature of the body orginally designed for a Slash, not a MT. It's hard to see the Goo, so I outline the area's were I put it on the body
I also went ahead and put on packing tape on the sides of the body to help prevent the paint from being rubbed off from the battery trays during crashes and heavy landings. A simple but effective idea I felt.
