Bmr4life
09.17.2010, 01:59 PM
DON'T DO IT!!! They aren't the same mah! The 5000mah will die before the 5200mah and you will go below 3V/cell on the 5000's before the 5200 hit the cut off, you risk destroying your lipos!
Just set the cut-off to a higher and safe number like 3.4v and it will be fine. That small 200mah difference isn't a big deal.
