rc4x4nut
09.22.2010, 12:39 AM
This is what I have sitting around. Its a nice if you need the flexibility
http://www.amainhobbies.com/product_...-138V-40A-520W
Fast5sRevo88
09.22.2010, 11:14 AM
Sweet, i looked at that before but didnt realize that could do 520w.
Duster_360
09.22.2010, 11:23 AM
Its also only 13.8v.....Duo3 will not develop its full 360watts of power with 13.8v input source no matter how many watts.
Fast5sRevo88
09.22.2010, 11:56 AM
You sure?, I mean the ohm's law thingy says that 13.8v and 40amps is 552watts. I dont know what to do i can get the amp and watt ratings it calls for but not quite the voltage. Maybe i should do a 24v battery setup and just buy a charger for them, 2 12v batteries aren't exactly portable. I'm assuming that i would have to have some pretty high mah 12v's am i correct?
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
09.22.2010, 01:25 PM
You can have a look at this thread from snellemin:
How to build a $20 47A power supply
Alien
Duster_360
09.22.2010, 01:47 PM
Look at the bottom of the 1st page -
http://media.hyperion.hk/dn/eos/EOS-...2-MAN-EN46.pdf
This has been discussed on more than one forum. You'll only see 160watts per port using a PS with less than 14.5+v, not 180watts per port. There is some component internally in the charger that has to have the higher voltage to enable full power, its not a matter of watts.
Was discussed in here -
http://www.rcgroups.com/forums/showt...highlight=duo3
