coolhandcountry
coolhandcountry's Avatar
02.26.2006, 05:39 PM
You say novak changed some things. Does that mean that are better?
GriffinRU
02.26.2006, 06:01 PM
Well, I am still collecting data on it...
so far HV ESC vs. EVX ESC:
- better water protection
- better FET's
- multi-layer pcb
- better BEC
- better 14 cells support, without mods can 16 (even 18, need to test)
fan support, external cap, external tabs...
Are you running the motors on different controlers? Or, are you running them on the same controler?
7XL runs on HV4400 controller, HV4400 motor runs free. I am using only sensors from Novak's motor to drive big motor.
Artur
crazyjr
crazyjr's Avatar
02.27.2006, 08:58 PM
Artur
thats what i was thinking, but its so out of the box, i didn't think to say it that way.:027: pretty cool idea. The only problem i see with the fegaio sensored is that the sensor plug won't be the same
GriffinRU
02.27.2006, 11:41 PM
Well, we can solve this with adapter.
your project definately has potential to be a great way to drive at low speeds and not have to worry about cogging.
Pulling stumps along the way...
It is spinning at high revs as well. Now, even small motors can pull nicely. I tried C50 14.4 in place of 7XL and it was very nice. I might consider C50 as a better match, 3 broken tranny gears and 2 melted spurs, too much damage. But I will keep updates on both.
Artur
