Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
09.23.2010, 02:18 PM
You really think I'll be hitting over 100amps with my set up ?? I dont doubt you but it suprises me a little.
1509 2Y-1820kv running 3s, vehical weight is 6.4lbs w/battery & body geared 50/20
Differential Ratio: 2.8461538461538462
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 50
Pinion Tooth Count: 20
Total Voltage: 11.1
Motor KV: 1820
Tire Diameter (inches): 3.85
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0.018
Spur/Pinion Ratio: 2.5 : 1
Total Ratio: 7.11538 : 1
Tire Circumference (inches): 12.1 inches (307.22 mm)
Rollout: 1.70:1
Total Motor Speed: 20202 RPM
Vehicle Speed: 32.52 mph (52.24 km/h)
Effective KV Value: 1820
KT constant: 0.74 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
