pinkpanda3310
pinkpanda3310's Avatar
09.24.2010, 11:34 PM
If the voltage is constantly sagging the system draws more amps to make up for the power loss and hence compiles the problem. If the LVC is set high that can sometimes be triggered too. If they are running maximum volts then ripple is most likely, as Arctik saying.
