09.27.2010, 11:34 AM
I've run my 1717 on 5s and the 35C packs were to warm for my liking even tho I was geared for 38mph in my XXL. The packs got hot and swelled a little, they recovered but The 1717 was to much for them. I would seriously consider useing no less than 40C in 5s, higher the better(Nano 50-90C?) . 6s I think is the basic sweet spot for the motor, It's a amp hungry pig and on 6s the packs stay ambiant temps.
You have to figure AT LEAST a 1/4" for tire balloning, 0.1 aint enough.
Differential Ratio: 3.3076923076923075
Transmission Ratio: 2.215277777777778
Other Ratio: 1
Spur Tooth Count: 44
Pinion Tooth Count: 22
Total Voltage: 22.2
Motor KV: 1580
Tire Diameter (inches): 5.84
Tire Ballooning (inches): 0.25
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 2 : 1
Total Ratio: 14.65491 : 1
Tire Circumference (inches): 19.92 inches (505.91 mm)
Rollout: 1.36:1
Total Motor Speed: 35076 RPM
Vehicle Speed: 45.14 mph (72.52 km/h)
Effective KV Value: 1580
KT constant: 0.86 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
