Originally Posted by Nard Cox
I've also been drawing several sketches to fit a CD in my Flux with a 1717 / 1520. The higher output cups on the CD vs the standard gearbox make it a pita. Also because the LiPo's will have to be placed that much higher.
I can see how the stock XL TVPs could make this difficult with the high center. My TVPs are basically stretched Flux TVPs, flat along the bottom. The front\rear dogbones in it are pretty much horizontal. What chassis are you planning to use Nard?
Listen up jive turkey, dont forget to put a decent cutout under that slipper
