Looks GREAT! Those are some very nice shots you've taken.
About that Racer's Edge servo arm. Can you tell me if the linkage hole is tapped for a 3mm Screw or 2.5mm?
Also, How does the Locking spindle part work out, does it clamp around the Spindle and Also use the standard screw to hold it on the servo ??? 4 total screws? Thank you, Sir.
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
Hey Zippy, thanks man... the servo arm uses a 3mm for the spindle hole... most of the holding force is created by the two tiny screws that are mounted through the sides of the clamp...
I used the M3 screw to push the arm down over the spindle because the initial fit is a little tight... If you want additional holding power from the M3 screw, you will need to shim the inside of
the spindle hole... the linkage hole is 3mm and you will be using a total of 4 screws...
Thanks Popoxx ... yeah, these lipos sure pack some punch... it's been raining here for a couple weeks, so no test runs on the track..
I did some runs on the carpet at office a couple days ago and it was whole lot of fun.. i'll make an update as soon as get the car on track.
