loc tite does not work with plastic diff cups.. if you can and its available, you should try and run the alloy diff cup! will allow no flex within the cup, and loctite will actually work
Is there a possible mistake with the KV written ON the motor?
My order came in today and I notice that the 1520 is quoted 1600 kv on the box and 1520 1y 1500kv ON the motor
I agree that it runs cooler then with the Pletty. It accelerates harder then the 1512 1400kv motor that I have. The weight is killer though, but I figured I stuck a V8 in Civic and have to drive different. Gearing is 46/23 and I'm waiting for Mike to get his 26T back in stock.
