Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
10.10.2010, 05:31 PM
The page you linked is for the RC8Be electric version. I think he is referring to the nitro version of the RC8B. I don't know if it makes any difference...
It's the same through out all of the 1/8 vehicles. i've got both of them.
here's the info from the nitro version as well:
•4.30:1 ratio gearboxes for maximum punch
http://teamassociated.com/cars_and_t.../Factory_Team/
RC8B Factory Team (nitro version)
Features
•Pre-assembled shocks, diffs, and turnbuckles with Factory Team shock and diff fluids included
•Factory Team 16mm Big Bore threaded, hard-anodized shocks feature heavy-duty 4mm TiN coated stainless steel shock shafts for maximum smoothness
•New 5mm 7075 blue aluminum shock towers allow the driver to stand the shock angle up for a more aggressive suspension
•Optimized front upper camber link bushings allow for more tuning options and are easier to adjust and maintain
•7075 blue aluminum suspension mounts front and rear, with inserts to allow easy and quick adjustment of rear toe-in, rear anti-squat, and front kick-up
•# Optimized steering geometry for more consistency and reduced bump steer
•Updated wing mount with additional clearance for 16mm shocks
•Molded composite radio tray includes optional forward placement battery box for increased steering
•Molded composite front and rear chassis braces
•Tough steel-alloy shock stand-offs
•Factory Team 83mm big wheels included
•Machined aluminum racing clutch shoes
•Lightweight engine mounts
•Factory Team 7075 blue aluminum one-piece top plate
•Light-weight 3mm hard-anodized chassis
•Heatsink brake discs with "FFC" Free Float Caliper brake system eliminates the possibility of unwanted brake drag while on throttle
•Two-piece split-center diff mount allows quick and easy access to the center diff
•Caster blocks adjust 14, 16, or 18 degrees with molded inserts
•3.5mm light CVA drivetrain with full ball bearings
•Rear molded CVA boots to keep dirt and mud out of rear joints
•Blue aluminum hexes and nylon locking wheel nuts
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
