KniteWulfe
10.11.2010, 09:15 AM
Originally Posted by nuz69 View Post
+1 on hyperion, 5000mAh 25C G3 is well enough for a 4S buggy ;) You said earlier that you have done the test with 2 different ESC + motor combos with same problem ? You should definitly check the batteries or the motor mount.
Could you be more specific about checking the motor mount? I don't see anything out of the ordinary.
