pinkpanda3310
pinkpanda3310's Avatar
10.11.2010, 09:23 AM
Originally Posted by KniteWulfe View Post
i was wondering about my connectors too, especially the esc battery connector. Its possible I had a bad joint somewhere and it got worse with usage causing the low voltage issues and the cogging. I really don't think my gearing could cause cogging on this motor in a buggy.
I don't see how that could be the source of the heat issues though, but certainly should be investigated. It would be more probable than having 2 bad 4s packs and 4 bad 2s packs.
If it was a bad connector then you would have more than one. It is the same problem with 2 different esc's and a number of batteries.
