How did you hook the receiver power backwards? The power wire is the center pin on the servo plug. If hooked wrong, the only thing that would happen is the ground and signal pin would be reversed. Any decent receiver should be able to easily handle a grounded signal wire, especially since it's not a high current line and the high possibility of users hooking it wrong.
