Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Semi Pro
Semi Pro's Avatar
10.10.2010, 03:17 PM
Originally Posted by mistercrash View Post
I took the LST out yesterday for the first time since the motor came back from Neutronics. It didn't take long for the motor to shred the rear diff... again. I know that a lot of people have very good results with LSTs and they swear by them. But it seems mine breaks a lot. The more I used it, the less impressed I am with it. Maybe 6S with that 1521 is just too much, 4S is not quite enough for a 14 pound truck. So I feel I should try 5S but that means buying some more lipos which I don't feel like doing. I'm seriously thinking of selling this thing as a roller with the 1521 in it, a set of 3S turnigys and most of all the parts I have for it.
losen your slipper!
my buddy was trashing front and rear diffs every run with a meduas 36-80-1600 on 5cell because the slipper was to tight
the truck now has 5 runs on it with the slipper set right running a 36-80-1100 on 12cell and the diffs are still fine
jpoprock
"Don't act like you're not impressed."
jpoprock's Avatar
10.11.2010, 08:17 AM
I agree with SemiPro... Loosen your slipper. I used to blow rear diffs all the time, especially when running big tires. What tires are you running Ray? I was running 40 series Big Joes on 23mm Commando rims. I loosened my slipper (more than I wanted, but it's a trade off), and put on some 40series low profile Bowties and haven't had a problem since. I love big tires, but of all the tires I have ran, I always go back to 40s Bowties. They are great on everything, they are wide, low profile, and light.
I'm running on an LST2 though, and use a Neu 1515 2.5d. I think that motor is probably one the best MT motors ever made, and it LOVES 6s. Perhaps that motor you have is too much afterall Ray?
ERBE: RCM 1/8 Hybrid Diffs, NEU 1515/2.5d/S MMM, 6S, Losi E-XXL CUSTOM, Neu1515 2.5d, MMM, 6s E-SLAYVO PRO ERevo Chassis w/ Pro 3.3 parts, NEU 1512, MMM, 4S.
  Send a message via Yahoo to jpoprock Send a message via AIM to jpoprock
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
10.11.2010, 09:17 AM
I fixed it yesterday, it was one of the sun gears that broke in two. I'll try readjusting my slipper again, it's already pretty loose but I gotta do something. Punch control is at 70% and I'm running Proline 40 series Mashers mounted on Losi 420 dish rims. They are not that heavy. I also had a bent front shock shaft. Yeah, 5 mm thick shaft is not enough to keep it from bending. Well there was this 12 foot high dirt hill and I jumped it sending the truck I don't how high. I was getting neck pains looking at it Good thing I made a spare.
No brain, no headaches.
10.11.2010, 04:24 PM
mistercrash-
I read the thread and skimmed over it a second time, I'm sorry if I missed it but-
What driveshafts did you use from the diffs to the tranny? Custom or did the stock units fit? Thank you!
mistercrash
Guelph, Canada, eh!
10.11.2010, 09:04 PM
I used a stock XXL middle shaft for the front of the tranny and a stock LST2 middle shaft for the rear of the tranny.
10.11.2010, 11:28 PM
sweet. thank you.
mistercrash
Guelph, Canada, eh!
10.12.2010, 11:06 PM
Anyone want this MC exclusive? PM me for price. The truck will be as it is in the pics and the parts you see will be in the box.
LST XXL converted as described in this thread with freshly rebuilt NEU 1521 1Y.
simplechamp
simplechamp's Avatar
10.13.2010, 10:07 AM
Just saw the ad over at RC Tech. Surprised to see you selling it, any reason in particular? Awesome truck, wish I had the cash. Bet it is nuts with that 1521
mistercrash
Guelph, Canada, eh!
10.13.2010, 01:11 PM
indeed it is nuts. Maybe a little too much I could get a different motor to tame the beast a bit like it was suggested to me but I would rather stop spending money on this and get back to flying RC airplanes. Mainly because my son is so interested in them so I'm thinking of a couple park flyers for next summer to ease him into it. And a RealFlight simulator for this winter to let us train on. I will need some training also since I haven't flown RC airplanes in a long time.
Finnster
KillaHurtz
Finnster's Avatar
10.13.2010, 04:30 PM
Brian I saw those and even though they look really nice, they are to short for the LST2 shocks I'm using. IMO, the only way to make them work properly with the LST shock cartridges is to do exactly what I plan to do which is to open the cartridge, enlarge the holes for the shaft and replace the O rings with ones with a thinner cross or thickness. Unless the Hot racing reservoir shocks use a cartridge that fit the LST2 shock body. I'm not sure. Maybe they could work but I wouldn't get the full extension that I have with the stock length of the shock shafts, it is something like 87 mm long if I remember correctly. Thanks for searching I appreciate it.
On an another note, I gave up on my E-Revo to go with the LST because I find it is tougher and easier to work on. But there are things on the E-Revo that I really liked. The tranny for one which I installed on the LST but also the Traxxas VDPs (Variable Damping Pistons) in the shocks. So I am going to try it on the LST with these little valves I made out of a piece of thin polycarbonate from some packaging that was lying around in the recycling bin. I know Hot racing makes pistons with tapered holes which are supposed to have the same effect, I'm just trying to do it on the cheap.
The valves block 10 of the 24 holes of the piston on compression which should give better, stronger damping, and the valves bend slightly to let the oil pass through all 24 holes of the piston on the rebound.
I made a second 5 mm shock shaft and ordered the Viton O rings I linked before. When all the parts get here, I can finally try out those shafts on the front end with the VDPs front and rear.
Hey, I just wandered into this thread and saw this mod. I was actually looking at this myself, but was thinking about boring out to 6mm, as I wasn't sure 5mm would cut it. (Had integy lst shocks from a muggy at one point w/ 5mm shafts, but they were soft and bent easy too)
Basically I have LST shocks on my savage, but the shafts always bend or snap at the shock end. I took apart the cartridge the other night and saw how it was built and seemed like it could use a much thicker piston rod. Just need a lathe or something to cut 5mm threads on it.....Dunno if a hand die would work well, or if the rod finish would be too rough.
Material: Multipurpose 4140/4142 Alloy Steel
Alloy: 4140/4142
Finish/Coating: Ground
Shape: Rods and Discs
Diameter: 6 mm
Diameter Tolerance: -0.0005"
Tolerance: Precision-Ground
Temper/Condition: Annealed
Hardness: Rockwell B92
Maximum Attainable Hardness: Rockwell C50-C55
Yield Strength: 60,000 psi
Too bad you are selling, looks like nicely made truck
Overdriven
Destroyer of Tires
Overdriven's Avatar
10.13.2010, 08:30 PM
Mistercrash, saw you're interested in park flyers. I too have been bitten by the flying bug. The flight simulators definitely helped me out a bit. Now I have a Parkzone t28 trojan and a micro t28 trojan. I have to say I recommend the micro t28. Its easier to fly believe it or not, and can be flown in a smaller area. I love coming home from work and flying it up and down my block. I've hit some power lines and then the ground, but nothing has broke, only pushed the lower cowl in a little. Great little plane, and on calm days someone with only simulator experience should be fine with it.
jpoprock
jpoprock's Avatar
10.14.2010, 09:48 AM
I have toyed with buying this from Ray because it is a sweet custom truck. But my buddies and I are working on our design using the Erevo tranny, so it would be silly for me to buy this. I've begged Ray to let me buy some of his spare parts that I need, but he wants to try and sell it all in one shot. (Look at me talking about him like he's not here, ha!). Ray: if u sell it, let me know to whom so I can see if he really needs all those parts!!)
I'd like to know who out there uses big tires with a big motor, like Ray does... And if they have diff probls too? I still say if you went to a 1515 and used low profile 40s tires like Bow Ties, it would solve the probl. Maybe just a tire swap alone would? I know that on this same set up, the bigger the tires, the more prone I was to blowing diffs. This tells me that the Losi diffs may not be able to handle it. Maybe the TiNi gears would help? I'm pretty sure it's the Losi diff or nothing right? You can't run anything else?
I'm almost done with my custom XXL chassis set up, Bro too, so, I guess I'll have to find out for myself and experiment with tires. Bro uses the Nova cups. I use the HD cups. Not sure if Ray used Nova cups or not. Ray?
Good luck buddy! Yer efforts were much admired!
Btw.. I too would love to own that flight simulator program! I've never messed with planes, but would like to someday.
J
mistercrash
Guelph, Canada, eh!
10.14.2010, 09:52 AM
Finnster
If you can get 6 mm shafts to work it would be good. The 5 mm shafts were better than stock but I did manage to bend one. I was able to bend it back straight. Then it did bend again in a bad landing from very high up. That's when I changed it with another 5 mm shaft I had made. I think the rods I used are just too soft.
Overdriven
Thanks for the suggestions, I looked up those planes and they are very cool. I bookmarked the website.
jpoprock
I used Losi HD cups. As for the 40 series Mashers being too heavy, my son has the same tires on his ERBE which is running the stock Traxxas diffs. I know it's not the same truck, and not the same motor and he doesn't run on 6S. But still he uses those same tires and the puny little Traxxas diffs hold up. I think the weight of the truck is the major problem, there's no way to make it significantly lighter. And the wheel/tire combo might be a bit heavy but really they are not THAT heavy. The motor might be too torquey but this heavy truck needs torque to make interesting to play with. And if another one tells me that the slipper is too tight, I'm gonna become very very angrrrrry
Can't wait to see those project LSTs you guys have in the works.
I READJUSTED MY PRICE ON MY LST XXL following the suggestion of someone and his nameless friends For those who PMed me asking for the price, I dropped that price by $50.
mistercrash
Guelph, Canada, eh!
10.18.2010, 10:28 AM
Deal pending
nitrostarter
nitrostarter's Avatar
10.18.2010, 11:42 AM
Can't wait to have some fun with this animal!
N. Rustler conversion
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
