joostin420
02.28.2006, 05:35 PM
thanx guys :027:
the CF comes from http://www.dragonplate.com
i have found that the Dragon Plate is stronger, and easier to cut with a scroll saw than other CF - it is glossy finished on one side.
no i didnt change the foam inserts on the komodos. should i, because they seem okay to me??
does anyone have any thoughts on what i could use as an undertray, and if i should even use one? i may just use a thin piece of lexan.
justin
Serum
Serum's Avatar
02.28.2006, 05:47 PM
I think you will find your answer in a .5mm thick lexan transparent plate. light and protective.
Did you ever tried CF from these guys?
joostin420
02.28.2006, 07:47 PM
i have not tried their CF, but i would imagine it will be very hard to cut. i have tried 2 other brands of CF and they are much harder to cut straight lines with a scroll saw.
justin
lydiasdad
03.01.2006, 10:16 AM
It is hard to cut, went through 2 new blades cutting one chassis.
joostin420
03.01.2006, 11:13 AM
wow, i went through more than that on other CF. to do the whole rustler-buggy chassis i went through probably 16-20 blades +.
justin
maxxdude1234
maxxdude1234's Avatar
03.01.2006, 01:32 PM
Was milling not an option?
joostin420
03.01.2006, 05:48 PM
i have no milling machine at my disposal, but i do have a contact that i am trying to work out a deal with to see if he can laser-cut chassis's for me. we are going to see if this method will cut cleanly without damaging the CF.
justin
Serum
Serum's Avatar
03.01.2006, 05:54 PM
isn't waterjet the best way?
let me know if lasering is an option, but isn't the large amount of graphite a pita to laser?
joostin420
03.03.2006, 08:30 AM
i will let you know what happens with the laser.
i am trying to decide which controller i am going to use on this buggy. i have a Schulze 12.97 and a schulze 18.97KWF. right now the schulze 12.97 w/ a hacker 8L on 12cells is in my TXT-1 and the controller gets pretty warm without a fan.
i know the schulze 12.97 has BEC but i dont use it in my TXT-1 because i run 4ws with 2x high-torque servos. my question is should i use the 12.97 in the buggy with the Nemisis 12s, and will i be able to use the BEC with one steering servo? i had originally planned on using the 18.97KWF in the buggy, but i think that it would be better suited in the TXT-1.
justin
joostin420
04.14.2006, 11:23 PM
some updated pics. just waiting to paint the body and for lipos.
justin
maxxdude1234
04.15.2006, 05:03 AM
Thats one great looking conversion joostin
Gustav
Gustav's Avatar
04.15.2006, 06:59 AM
Yeah,that is one awesome looking RC there.
boss 302
04.15.2006, 08:14 AM
that thing looks awesome
MetalMan
MetalMan's Avatar
04.15.2006, 09:35 AM
That really is looking very nice. I'm thinking of making a new chassis for my BL/Lipo Rustler. You wouldn't mind if I did something similar to yours, would you? I would be using Garolite or aluminum for the chassis, and a different body, so it wouldn't look exactly the same.
coolhandcountry
coolhandcountry's Avatar
04.15.2006, 03:18 PM
It looks like a buggy now with the body. Sweet.
Peace!
Country
Help support the
Rc-Monster
Buy here
