10.21.2010, 02:13 PM
The Gorillamax is the best and most sought after revo chassis IMO.
For racing I would add sway bars and consider adding a centre diff using mikes mount. It will lower you COG alot and will make it perform like a race truggy. For this reason though your track may not let you run in MT class.
Worth checking - If the say no as if you can run a spool / locked cdntre diff.
medicineman
medicineman's Avatar
10.22.2010, 02:33 AM
so if i have a front and rear diff is the center diff that helpful?
i also looked up the gorrillamax chassis and i think your rigth it is suppose to be one of the best but if is so good how come on one has it. and i think i am going to add techno front sway bars and traxxzas rear sway bars.
Has anyone else noticed that the poeple at the track are very helpful untill they find out you want to race.
  Send a message via Yahoo to medicineman
