andreazinno
10.26.2010, 10:26 AM
Originally Posted by Bmr4life View Post
Nice mount.
What gearing and battery did you use with the stock motor?
My last test was with a Medusa 36-80-2000 (2.000 rpm/volts) on 5s.
With this setup, I've used 23 or 24 tooth pinion on 52 tooth spur. No heat problems at all.
The mount is made of Anticorodal (Aluminium 6062), not so strong as Ergal, but much easier to work on.
Bye, andrea.
