josh9mille
josh9mille's Avatar
10.29.2010, 09:55 PM
If you don't want to cut off the switch, use a traxxas mount for the MMM. Yes it fits, but just barely. And you have to grind down the "lip" of the esc mounting pad in two places. On the left side (motor wire side in my pic) so the esc can sit flat, and a little in the rear so the traxxas mount can sit flat.
Ya i figured out i could use the trx mount right after i drilled the holes for the ziptie lol. Your motor wires are at least 2 times as long as mine, i wonder why? I had to mount mine the other direction in order for the wires to reach. How did you run the wire going to the reciever?
