Experimenting.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Experimenting. - 11.02.2010, 12:39 AM
It actually sounds like a nice experiment, but it really doesn't make a lot of sense to me. Imagine a cheeta having stronger front legs than back? I believe that it would seriously effect the way it chases down prey in a negative way. It seems to me that it would not be very efficient in comparison to having all four corners pulling nearly the same weight under the same power. If you have your diffs setup for better handling, which is setup to match the actual drivers preference that should be enough. BUT like I said it sounds like an interesting experiment to try. So give it a shot and share your results with us.
SUPERMAXX YOUR LIFE.
