You might be surprised. 5S/6S batteries are fairly heavy. However, yes I suppose that the traction would probably increase when running on asphalt. Much different than on grass, loose dirt, etc.
Originally Posted by Bmr4life
That's correct, but batteries up front wouldn't have helped nearly enough. I'll have to post a video of my 5B on asphalt. Simply moving the batteries up front wouldn't have solved my problems.
Yeah, I was only running 4s. 2 hard case 2s Turnigy lipos. With 5s/6s, I'd think it would be even more likely.
I was using the Terrapin tires, not sure if their large diameter had any effect on it.
