EDS
11.06.2010, 12:57 AM
Thanks guys
Wednesday I filled the shocks with oil and the diffs with fluid. Yesterday I spent alot of time installing the electronics. I tried to wires the best I could. To make room for the hobbyking 100a esc I decided to stand the servo up. So I had to make lexan servo mounts and then extend the servo saver arm upwards to make for a better angle.
Today I glued up the tires which went horribly because the Losi Step Pin tires didn't fit the Jconcepts wheels very good. I believe the losi's use a different bead type then the wheels but I did my best.. Afterwards I charged up the battery and took it out for a test run even though I had a couple things to finish up on like the wing mount and drilling out the shock mount screws ( the ones that go thru the shocks) The test runs went surprisingly well! Everything in the transmission held up. I definatly need put the front sway bars back on because it easily traction rolled but this is also because it was on the street. I broke the shock mounts because the screws to hold the shocks on weren't in all the way and I couldn't drive it with the body on becuase I have to save the body for when its sent to location X. Thus when the buggy traction flipped it slid on the rockers and shock screws. The buggy is fast at full throttle. Everything worked great. The real test will come in the next couple of days when I take it to the track.. I will be trying to get a video of it but it probably won't be a great video because I will have to use a digital camera.
Video soon though =)
el tomaso
11.11.2010, 12:18 AM
I love the buggy, i really hope it performs good after all the work you've done to it
Thomas G
