Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
George16
Supermaxx
George16's Avatar
11.11.2010, 11:57 PM
15 or 16mm will work just the same. There's not much difference strength-wise between the 8x16x5mm against the 6x15x5mm bearings. I'd rather install a pair of setback arms in order to give an additional 22mm of length. It will be more stable and less prone to wheelies and flips.
I have both 15 and 16mm versions of racerx and I can't able tell the difference.
Edit: 16mm racerx is required if you're going to use the 8mm cvds unless you have a readysource of 8x15x5mm bearings.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
