Ejector pins
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Ejector pins - 11.12.2010, 07:43 AM
If you are talking about the ejector pins being used for hinge pins, then yes. I have mine cut flush on both ends so they do not interfer with anything at all. The first set that I cut I left the ball ends on and inserted them from the front. That way there is no possible way for them to come out, because the bumpers keep them in place. When I purchased mine I ordered 8 of the 14" pins so I would have plenty of spares. We do have six SuperMaxx trucks though, plus two stocker trucks. If you are using the RCM Hybrid diff/bulks they will work just fine. I also tapped out the setscrew holes to use a bigger setscrew for holding the pins in place. Those little tiny ones strip out way too easy for my liking.
SUPERMAXX YOUR LIFE.
