Thread Tools Rating: Thread Rating: 57 votes, 4.93 average. Display Modes
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
11.12.2010, 01:31 PM
I'm taking another chance with Dan, I'll see how it works out. I was a little bothered by the wide track of my ERBE with those LST XXL shafts so I decided to see what I could do to bring the track back to normal. It was simple enough, the axles of the shafts are hardened steel but not quite hard enough to keep from using ordinary drill bits on them. I made new 3 mm holes to reposition the hexes where I wanted them and used an ordinary but good quality M5 tap to make deeper threads inside the axles for the grub screw to go further in.
Here's the new hole. I measured the center of the hole to be 19.5 mm from the tip of the axle.
Installed on a spare RD Racing axle carrier with a thick aluminum shim that is used on the pinion of an LST XXL diff.
So I don't have to measure each time to drill the holes, I made a jig from a scrap piece of metal. The axle slips into it and I just have to insert the drill bit in the correct hole. This block of metal was used for many other projects as a jig so that's why there are many holes in it.
I now have LST shafts on with the correct track width on the truck.
No brain, no headaches.
