Jahay
11.12.2010, 10:19 PM
You can use a hellfire alloy diff cup which uses an 8x10 bearing, but you will also need roughly 32 shims to shim out the internals of the diff if using savage spider and bevel gears. It is defintely worth doing, and i will eventually do it at some point.
