11.15.2010, 03:03 PM
Thanks for that info!
The "transmission" will be "1" if it is just a center diff. Most b/truggies have no transmission, just a F/R diff and Spur/pinion.
Typical 8th scale buggy diffs are 43T ring gear, 13T pinion gear, if that helps you out. If all else fails, just count the teeth (sometimes you can even count the teeth on the PDF document when blown up).
