Originally Posted by RC-Monster Mike
I find it interesting that people would even consider using a 17mm wheel adapter set that was designed specifically for a different vehicle(so it "might" fit the intended application), when my adapters will be transferable to pretty much any car with a 12mm hex. Any adapter that is sized to a specific axle will have potential tolerance issues and fitment issues on any vehicle it isn't specifically designed for - this is why my hex adapters are the way they are - they can fit snugly onto the stock hex for near perfect concentricity AND universal fit to many vehicles. How many hours is someone willing to spend to save $5-$10 on a "might fit" when they could simply use my adapters that do fit? In my mind, if you go to work for $10/hour, then any time over 1 hour is simply devaluing your time when searching for a cheap alternative - assuming you can actually save $10 (and the real loss may be much worse if they don't work, don't work well or require additional time to make work). You could just as well put in an hour of work for free and buy my adapters that DO WORK. If you make more than $10/hour, then the math is even worse. What am I missing? My adapter set consists of 4 hex adapters and 4 nuts, so 8 pieces total(and each piece requires 2 machine operations and setup) @$4.50 per piece or $2.25 per operation for cnc machined aluminum goodness. This is considered "pricey", but spending hours to save $5 somehow makes sense?
+1
I'm with you... Why screw around?
I've run the RCM adapters on the CRT.5 (pictured) the Mini Hyper and the SCRT10 and they worked perfect on all of them.
