LiqrSicc
LiqrSicc's Avatar
11.18.2010, 02:35 AM
Originally Posted by josh9mille View Post
Hold the spur gear with your finger
Also I didnt know HPI made a savage 5T? Got a link? EDIT: nevermind I found it. Why didnt you also get the 5T 17mm hex's? Then you wouldnt have had to mess with the spacers and stuff.
Yeah holding the spur with my finger I cant get it tight enough as it's slipping a lot right now. I have to take off my botom skid, remove my motor and esc just so I can tighten my spur. Weak.
Oh, the 5T hexes are 23mm BTW, plus I wanted a little offset.
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
  Send a message via AIM to LiqrSicc
josh9mille
josh9mille's Avatar
11.18.2010, 04:11 AM
You can also try putting a penny between the pinion and spur to lock them up so you can tighten the slipper, a penny is soft and wont hurt the gears but im sure you would be ok using anything really
