Thread Tools Rating: Thread Rating: 17 votes, 4.76 average. Display Modes
Knez
Knez's Avatar
01.09.2011, 02:52 PM
yes 1520 should be ok, i need esc that can handle 6S as my MMM V3 just keeps burning up on 6S...a bit later i intend to go with center diffs or GCM trany.
Flux 5B CC 1520
1/16 Rally
My Youtube
Russian:Life and Trust is Lost Only Once!
Knez
Knez's Avatar
02.15.2011, 01:33 PM
A teaser :) lol, tires are form FG MT, thsoe suckers weight like + 650g.
Will not use them, but culdnt help my self to put them next to a F5b.
This is how i intend to set a roll cage hight, will cut tvps roof, also need some custom made towers..soon i hope.
Also got the custom made rear light, lol.
For front i got traxxas led light for summit, aint much but looks ok.
Also got Hitec HS-5755MG, mamba XL, cc bec pro and quick connect so i finally put my 5b together.
Well i did get the
A friend also put hes together, so we just made a fast test so we see all is ok.
Flux 5B CC 1520
1/16 Rally
My Youtube
josh9mille
josh9mille's Avatar
02.26.2011, 02:23 PM
I dont really like how Alza racing does business myself. I have seen their 5B TVPs on ebay, and its not an auction or a BIN for the TVPs, but you bid on the information on how to buy them. Kind of a scam if you ask me.
toplakd
02.26.2011, 02:30 PM
If you have read carefully, you will see that for 0.99$ you get 5% voucher code for that particular product in store.
Scam is when you get nothing but information.
If you check on ebay, a lot of companies advertises their sites that way. Especialy when you are new company and you can not afford advertising campains.
And they are all selling coupons and vouchers.
And ebay is a place where lot of people are serching for products.
You are not bidding on information. Please read again, before you say it's a SCAM.
Thank you, Dejan
I removed my signature.
FG101C
02.26.2011, 02:33 PM
I knew it, all universities are a scam. Take it easy, just a joke.
toplakd
02.26.2011, 02:48 PM
Dejan
Knez
Knez's Avatar
03.06.2011, 08:43 AM
Small update... I cutted middle "support tower" of the HPI baja roll cage, wich i will not be using and made body mounts. Drilled m3 hole to m4 so i use m4 screw...
I didnt have a lot of black colour left so i finished with white..
Flux 5B CC 1520
1/16 Rally
My Youtube
Knez
Knez's Avatar
03.06.2011, 03:43 PM
Frond body post i made also from support tower form hpi roll cage and i drilled M3 hole in to the traxxar receiver box mounted small part on it, made another hole for body post... this menas my body is secured with 3 body posts.
Well for front part didnt came out as i wanted so i will be putting back front bumper... just sits to low like this as body is a bit higher do to the jubo servos wich dont alowe body to sit lower.
Front part was serured with those 2 lights...srewd 2 screws in and cutted them that screwd the "lights" on.
AS u can see on th last picture, it dosent look good! I just cutted to much and sits to low at the front...
Knez
Flux 5B CC 1520
1/16 Rally
My Youtube
toplakd
03.06.2011, 03:44 PM
I think your servo is to big. Cut the body, so the servo sticks out, and body will go lower.
Dejan
Knez
Knez's Avatar
03.06.2011, 03:49 PM
Than i would have to cut a bit for traxxas receiver box to...hmm, will see..maybe i do cut the body..
But bumper is also good to protect the front part a bit..as now my front is totally exposed.
Flux 5B CC 1520
1/16 Rally
My Youtube
Knez
Knez's Avatar
03.12.2011, 04:26 PM
Small video form today
Savage Flux 5b offroading
[YOUTUBE]http://www.youtube.com/watch?v=g9RTF2J6WW8[/YOUTUBE]
Everything was in the 30°C ambient only clutch at the end of video got to a 111°C i could even smell it, cooled down fast as weather was 7°C.
Had few issues with slipper as it was tightened all the way and got lose, will try to use 2 of those suckers, need to lock tight it totally.
Flux 5B CC 1520
1/16 Rally
My Youtube
Knez
Knez's Avatar
03.16.2011, 09:42 AM
Received tires and rims for "bajas", just need to get hexes and i am good to go.
Also got the HPI baja 5b bumper set "part number 85420", will try somehow to install the sucker so i can use baja roll cage.
Tire/rim info:
- Outer tire diameter 175 mm
- Tire and rim width 62 mm
- Rim inner diameter 119 mm
- Weight for one tire and rim combo is 375 gramms
Flux 5B CC 1520
1/16 Rally
My Youtube
Jahay
05.07.2011, 05:04 AM
hi bud! The videos are awesome!
They are both performing really well...
Silly quesiton here, but are you just using a body clip pin to hold the wing on the stock body mounts??? Or another method? Any closer pics?
THANKS
Josh
thzero
05.07.2011, 08:03 AM
That's what I did... the Savage body mount posts fit perfectly with the Baja 5B wing, then I just used some heavy duty body clips.
Knez
Knez's Avatar
05.08.2011, 06:44 AM
Hi Jah!
As thzero sad, only body post are holding the wing and baja 5b wing is perfect fit. Thanks for comments :)
Hope u make video soon of ur red devil!
But wing is not 100% stabilized it is moving a little. Would recomend some washers or something in between to fill the gap/space and to act as a support for the wing.
Name:	DSC05332 (Custom).JPG
ID:	9920   Click image for larger version
Name:	DSC05333 (Custom).JPG
Flux 5B CC 1520
1/16 Rally
My Youtube
